Hi Sawmill
In one of your posts from 2013 you stated that you had posted a video showing you using the circle cutter.
Would you mind posting a link to it as I can't find it?
Thanks
GeorgeM
Circle Cutter
Re: Circle Cutter
I assume you are talking about the SS Band Saw circle cutter.
FWIW, I have had one for years and it works perfectly. However, you do have to set it up correctly. Exactly as the manual states. If not it will fail miserably. It is not a big deal but attention to detail vis-a-vis the orientation of the center pin to the leading edge of the blade is critical to proper operation. Once set up correctly it cuts perfect circles.
Of course a video is worth 1000 words.
