planer feed motor problems
woodmeister
have a ss mounted planer barely uses yet the feed motor does not work, Tool two long screws out blew the brushes off and around the wrappings. Don't smell like it was burned and the shaft turns freely when rotated. Hate to buy one if I can fix unit cheaper. Any ideas??
Thanks,
Tom
Thanks,
Tom
Re: planer feed motor problems
PIX!woodmeister wrote:have a ss mounted planer barely uses yet the feed motor does not work, Tool two long screws out blew the brushes off and around the wrappings. Don't smell like it was burned and the shaft turns freely when rotated. Hate to buy one if I can fix unit cheaper. Any ideas??
Thanks,
Tom
We have seem several cases of the controller failing so I would not just blame the motor..........
woodmeister
i have a stand alone planer too. I took the motor and plugged it into my stand alone and the gear did not turn. The controller works to turn motor on the planer to operate the cutters but will engage the motor for feeding the work through on the shopsmith mounted planer. any ideas?
Thanks,
Tom
Thanks,
Tom
Not a good idea unless it is also a SS planer.woodmeister wrote:i have a stand alone planer too. I took the motor and plugged it into my stand alone and the gear did not turn. The controller works to turn motor on the planer to operate the cutters but will engage the motor for feeding the work through on the shopsmith mounted planer. any ideas?
Thanks,
Tom
If not, the rest is inconclusive.
The SS controller controls the feed motor only.
Two long screws??????
woodmeister
Yes it is the same motor and controller used in my shop smith stand alone planer. Two long screws hold the casing together and are put into the end with plug wire.
woodmeister
woodmeister
woodmeister
sorry for repeated posts. trying to delete them and seem to send more, ugh how do we delete multiple messages?
woodmeister
