Palm Sander for Christmas?
UncleSnick
Post by UncleSnick »
Hi All,
Looking for sage advice from this group of experienced woodworkers.... I was thinking of getting a palm sander but haven't started looking yet. Do you have a recommendation, a favorite one or a model I should specifically stay away from? Thanks - Nick
My shop is my time machine. I go there and lose all sense of time!
Greenie Serial 293128 March 1955
Greenie Serial 300735 August 1955 - Bad shape, future restoration project.
Grey Serial SS102778 Sept 1981 - Reversible shorty SPT driver.
Grey Serial SS168100 Feb 1984
Band saw Serial SS48432 Sept 1981
4" Jointer Serial SS91521 Nov 1985
Jigsaw Serial 33556 Jan 1984
benush26
Re: Palm Sander for Christmas?
Post by benush26 »
First some questions.
1/4 sheet or RO?
Corded or battery?
I recently bought the Bosch 1/4 sheet corded because I have their 5"/6" RO combo and really like it.
The 1/4 sheet is handy for what it does. Good or great? That I'm not certain.
Ridgid has a battery operated one (I have the Gen 5x set) and had given it a thought but seems to have more bad reviews than good.
Not sure if any of that is a help,
Be well,
Ben
UncleSnick
I was thinking corded RO.
GoNavy
Post by GoNavy »
I have had the Bosch ROS20VSC for a couple years now, and it has handled every thing I throw at it with ease, for under $60 bucks you can't go wrong, not to mention the little dust collector canister thing really works, you have the option to hook it to a vac, but so far haven't felt the need to do so, the little dust canister seems to work good enough as good as a vac on other sanders, variable speed ROS sander, made a little wood tool to align the disks quickly (5 inch 8 hole disks) this is a corded sander.
pic is ROS10, but they look identical, single speed is $10 cheaper, but the variable is worth the extra ten bucks
garys
Post by garys »
I have a couple of cheap ones. I like them for jobs like plaster or rough sanding on wood jobs. I don't use them on furniture quality jobs because they are orbital so they leave marks across the grain of high grade wood. You don't want orbital marks on a chest of drawers or a dining room table. If you are making a picnic table to sit outdoors, they work just fine and the sanding marks aren't a problem.
ERLover
Post by ERLover »
garys wrote:I have a couple of cheap ones. I like them for jobs like plaster or rough sanding on wood jobs. I don't use them on furniture quality jobs because they are orbital so they leave marks across the grain of high grade wood. You don't want orbital marks on a chest of drawers or a dining room table. If you are making a picnic table to sit outdoors, they work just fine and the sanding marks aren't a problem.
I use them up to my finial grit, then that one is done by hand with the grain. No swirl marks.
