Would like to use a remote switch with my SS dust collector - seems like I'm always on the wrong side of the shop when I need to turn it on.
Specs state this unit uses an 8 amp/1/2 HP induction start motor.
Located a remote switch transmitter/receiver at the local hardware store which states 15 amp/1875W resistive rating.
Is this switch acceptable for use with the DC3300?
[Fairly OK with grain and stain, but not much good on electrical stuff!]
Thanks!
keninar
DC3300 remote question
Re: DC3300 remote question
ok as it has almost double the load capacity.
Thank you, Kindly!
The kicker is 'resistive'. It may not like the motor inductance.
FWIW, I use the one Woodcraft sells. I used it with a 1 1/2HP JDS dust collector and now I use the same one on my Clearvue cyclone.
Q I have been using the Long Ranger from Penn State for a couple of years and I am very satisfied with it. Has pocket remote which you can just tuck it into shirt pocket
