What to do with it?
What to do with it?
My neighbor across the street put this out by the curb with a sign that said "If you want it, take".. I took my two wheeler and Took it. Now what? 1 1/2" MDF sandwich between Formica. I am thinking maybe a router/glue up table, maybe a work table of some sort, just don't know. I need some suggestions.
I can always put that sign back on it "If you want it, take it"
Don G
Don G
- IMGP0053 re_edited-1.jpg (547.66 KiB) Viewed 10835 times
- IMGP0054 re_edited-1.jpg (590.7 KiB) Viewed 10835 times
- IMGP0055 re_edited-3.jpg (503.85 KiB) Viewed 10835 times
ERLover
Re: What to do with it?
What ever you need a table top for. What are the widthxlength demintions?
The top is 48" x 24", the bottom shelf is 42" x 12"
Don G
Don G
ERLover
If you got the room keep it, glue up table and for finishing.
Put it back on the curb and re-use your neighbors sign
OR just fix them.
Not sure how you can go wrong with that...
JMO
Hobbyman2
JMO
Hobbyman2
ERLover
Thanks for the pic fix!! By the fence pic it looks like you got about a $200 router table without a router. Still if not you got a steal. In a NY minute I would keep that if I had the room.
ERLover
He just did not finish it and cut out for a router face plate. See here, just an example.
https://www.mlcswoodworking.com/shopsit ... letop.html
- ChrisNeilan
I like your original idea- glue up/assembly table.ERLover wrote:He just did not finish it and cut out for a router face plate. See here, just an example.
Chris Neilan
