Black & Decker Workmate
ChrisNeilan
Post by ChrisNeilan »
Dusty posted a while ago about a Black & Decker Workmate. That got me wondering where I had put mine. Looked for it for a while and found it hiding behind my furnace covered in dust webs- don't remember putting it there. He is right, a great tool. Mine is pushing 20 years old and none the worse for wear. I could have put it to good use recently! He was referring to the good quality of the original Workmate. I don't think mine is an "original", but it is well built! Still available from Amazon and elsewhere-
https://www.amazon.com/WM225-Workmate-4 ... r+workmate
Time to clean it up and put it to use!
Chris Neilan
garys
Re: Black & Decker Workmate
Post by garys »
I bet you could make it into a great stand alone router table for a big router. I had an old Hirsch saw table sitting around unused so I mounted my 2.5hp router in it. It works great for making raised panel doors.
The picture you posted makes me think that maybe, just maybe legs for a new one would fit on mine (which is definitely an earlier vintage).
It works well as an adjustable height outfeed table as well.
My Workmate shows up from time to time here when I show projects and have it set up for use or for being a table or for what ever. In this thread you can see it pretty well. So far as I recall this is an original of this version.
http://www.shopsmith.com/ss_forum/begin ... t6007.html
I don't know how close the new is to the old but the general idea has remained the same.
thunderbirdbat
Post by thunderbirdbat »
Interesting that they have 3 different models now WM125, WM225-A and WM425-A. I never got one but looked at them a few time.
Brenda
1998 bandsaw
2016 beltsander
jointer
overarm pin router
ChrisNeilan
dusty wrote:The picture you posted makes me think that maybe, just maybe legs for a new one would fit on mine (which is definitely an earlier vintage).
Are the legs broken on yours or the leg catches? Leg catch is available:
https://www.amazon.com/Black-Decker-242 ... e+255+legs
Chris Neilan
Thanks Chris. Those don't look like they would work on mine but I'll check it out.
What I know I need is a replacement leg. Mine somehow got bent. I actually picked mine out of a dumpster some twenty years ago. Should have looked for a leg then.
ChrisNeilan
dusty wrote:Thanks Chris. Those don't look like they would work on mine but I'll check it out.
Slow day at the office, try here!
http://www.ereplacementparts.com/black- ... _4342.html
Chris Neilan
Gene Howe
Post by Gene Howe »
Went to a divorce sale about 10 years ago. The ex wife was selling his tools. Got two work mates for $3 apiece. She thought they were worthless because one side of the table came off when she was moving them.
I've still got them and, I never fixed those tables. ;)
robinson46176
Post by robinson46176 »
I believe that my oldest one is the original style. The later ones were all steel frame. My old one has a cast aluminum center frame.
My old style B&D workmate.jpg (58.26 KiB) Viewed 6539 times
