Is there a way?
Where/how etc..
Changing logon password
Re: Changing logon password
Easy Peasy.JPG wrote:Is there a way?
Where/how etc..
Will probably look a bit different in whatever board style you are using.
Here is another way.
- Capture.PW JPG.JPG (130.14 KiB) Viewed 3349 times
Less 'Peasy' "over here".
- 1) Home.jpg (62.63 KiB) Viewed 3317 times
- 2) control panel.jpg (61.8 KiB) Viewed 3317 times
- 3) profile.jpg (52.83 KiB) Viewed 3317 times
- 4) finally.jpg (77.81 KiB) Viewed 3317 times
I'm confused. Are you asking another question or showing how to do what you asked about in the initial post.
dusty wrote:I'm confused. Are you asking another question or showing how to do what you asked about in the initial post.
"Over here" in the forum version I prefer and use, the access to account settings is slightly buried.
Your post showing control panel and profile led me to the account settings,(Thank You)
Yes I showed how I did succeed and what path was needed to get there.
Hopefully it will help another as dense as I.
Good. Very Good.
The path to many of these forum functions is a bit blurry.
