Interesting time ordering a quanity of 2
Conical disk is on sale and since I have an order going in I needed a couple of special washers. Went to the drawing and found the part and tried to put quantity 2 into the cart. It did not want to do that. After several tries I gave up and went back and added a second item, same part number. Now I have 2 lines with the same part numbers, quantity 1 on each line. And yes I did attempt to change it in the cart as well.
Anyone have a similar issue or was I just lucky?
I'm pretty sure I've been able to order two parts or three or four all on one line but maybe this has happened before????
ChrisNeilan
Re: Interesting time ordering a quanity of 2
Post by ChrisNeilan »
Gremlins?
Chris Neilan
rpd
Post by rpd »
Perhaps it's an Easter Egg in the program. ;) ;)
When to check my order, the two washers are still on separate lines in the system. It will be interesting to see if they get pulled together at some point. Well at some point in the order system, I figure they will get together in my shipment anyway.
Let's just hope they don't ship one and put the other on back order. :eek: :rolleyes:
dusty wrote:Let's just hope they don't ship one and put the other on back order. :eek: :rolleyes:
Sounds exactly like something they might do!
Beltsander ready for a rebuild, not sure if I need them or not but better to have them then need them and not have them.
Boy I have a stack of work ready for me............
