when the table is lowered all the way down, the left edge hit the top of headstock first , then it effectively keeps making the table tilted (right side lowered).
of course, i could have tight table tilt lock harder, but i do not want to overtighten it, or could stop lowering before the table hit the headstock. However, i'd like to hear from expert.
is there any stopping mechanism missing in my setup? or others are just dealing with it?
2nd question:
when you adjust the table height, how do you handle the floater and extended table connected the main table and maintain the level? let alone, it is very difficult to raise/down the main table using the crank when the extra tables are connected with the tubes. i have cleaned it and waxed the table post and holes using johnson paste wax throughly.
needs some advices and tips from expert.
