Newb diving in
Newb diving in
Just bought an old 10ER with "all attachments" and additional jigsaw setup - I think I got a deal? Ha. I have no idea what I'm doing so I figured I'd start sanding and painting before I even know what goes where or if all is accounted for. I just loaded it all up, brought it home, and set all the acoutrimonts in the corner of the garage.
Haven't decided if I'll do the smaller footprint vertical storage or the standard horizontal bench. Though I'd see primary use as a lathe most likely.
I've heard there's lots of great info on these fantastic machines. I'm interested in any beginner info and finishing recommendations; paint types/brands - anything to avoid...
Re: Newb diving in
IMO
I like the look of grey hammered enamel .
Have fun
Have fun
Re: Newb diving in
Far more than you imagined you needed to know.
http://www.shopsmith.com/ss_forum/maint ... t3503.html
Re: Newb diving in
Thanks, gents. Wow there's a lot of info out there. And I have some work ahead!
Re: Newb diving in
Hi Mike. Welcome aboard.Ek1050 wrote:Just bought an old 10ER with "all attachments" and additional jigsaw setup - I think I got a deal? Ha. I have no idea what I'm doing so I figured I'd start sanding and painting before I even know what goes where or if all is accounted for. I just loaded it all up, brought it home, and set all the acoutrimonts in the corner of the garage.
Congratulations on your acquisition,
We would love to see pictures of your prize.
If you are wanting to use it as a lathe, (good choice) I would go with the standard bench, (more solid), and make the legs so that the spindle is at your elbow height, that will be the most comfortable for turning.
Here is a link to a book that tells how to use your 10er that you can download. https://www.dropbox.com/s/x8nssglpvm4jj ... e.pdf?dl=0
And here is a link to the manual for the jig saw. http://vintagemachinery.org/pubs/detail.aspx?id=2703
Re: Newb diving in
Welcome Mike ! And welcome to the addiction !
Paul
Paul
Re: Newb diving in
Welcome, and thanks for the rescue!!
Re: Newb diving in
So the basics are restored and look alright. I used a lot of the info here to get her up and running and looking pretty again.
I am looking to do chess pieces. I want to mount the drill on the tailstock to drill a hole in the bottom to add weights later. This might seem like an easy answer but the search on this one wasn't too helpful.
Re: Newb diving in
Glad things are working out on your machine.Ek1050 wrote:So the basics are restored and look alright. I used a lot of the info here to get her up and running and looking pretty again.
So what did you want to know about mounting the drill chuck to the tail stock and drilling?
In general you will need lathe arbor if you don't already have one. See here:
http://www.shopsmith.com/ownersite/cata ... arbors.htm
You then mount the drill chuck to the arbor and then into the tail stock. The bit is mounted in the chuck and a center in the lathe to make sure the points align.
Once adjusted the work piece is mounted to the face plate or into the chuck and is advanced into the bit with the quill with the piece turning.
If you need more details let us know.
Re: Newb diving in
Ed I'm still confused on how to get the stem to fit in that tailstock hole.
It's 1 inch wide. Am I missing a fitting or a part somewhere?
