Bandsaw Wheel Bearing Lubrication
commnthings
Post by commnthings »
In the Maintenance section of the User Manual, on Lubricating the Upper Wheel Bearing, it says to use "cup grease or furnace bearing grease." I can't find either of these in my local Home Depot or hardware stores. Is there a suitable alternative grease for lubricating this bearing? What about white lithium grease?
Thanks,
Re: Bandsaw Wheel Bearing Lubrication
I use wheel bearing grease and pack the bearing as if it was on a front wheel of my car.
Don't know if this is correct, but this system has worked well for me.
commnthings
Thanks,
commnthings wrote:In the Maintenance section of the User Manual, on Lubricating the Upper Wheel Bearing, it says to use "cup grease or furnace bearing grease." I can't find either of these in my local Home Depot or hardware stores. Is there a suitable alternative grease for lubricating this bearing? What about white lithium grease?
Thanks,
I too use wheel bearing grease.
Wheel bearing grease is cup grease(the wheel bearings reside in a cup race).
commnthings
JPG wrote:Wheel bearing grease is cup grease (the wheel bearings reside in a cup race).
Who knew? Many thanks.
I googled cup grease and I think my previous statement is questionable. :o
In any event 'cup grease' is used for roller bearings which is the case for the bandsaw wheels.
I do think wheel axle grease is acceptable. I have used lithium grease but cannot say anything about it's durability.
I think the main thing is thicker than oil!
rlkeeney
Post by rlkeeney »
I use sythetic high temperature wheel bearing grease.
If it's good for truck wheel bearings the band saw bearings should be fine.
