Plywood Edge Banding
berry
Post by berry »
I wondered if anyone knows if plywood edge banding, the iron on stuff from Home Depot for example, can be painted after it's applied.
Thanks for reading.
thunderbirdbat
Re: Plywood Edge Banding
Post by thunderbirdbat »
I have used stain, polyurethane and varnish on it. I have not used paint but would assume it could be since the others work.
Brenda
1998 bandsaw
2016 beltsander
jointer
overarm pin router
mbcabinetmaker
Post by mbcabinetmaker »
If you are using wood veneer edge banding it will paint fine. Don't try it with the plastic's though.
Mark
2017 Power Pro Mark 7
