Its not really a lot different, I just used Krylon Crystal Clear Acrylic Flat instead of a satin finish. I think I like the Krylon Crystal Clear Acrylic satin finish better. However, The flat does look fine and works well.
The other car is here: http://www.shopsmith.com/ss_forum/viewt ... 38#p234538
Wooden Toy Car, Hot Rod 1932 Ford Sedan V2
Re: Wooden Toy Car, Hot Rod 1932 Ford Sedan V2
The Ford v-8 would have been in that car.
It had three exhaust ports. The center two
cylinders were siamesed into one.
- imagesflathead.jpg (14.37 KiB) Viewed 6306 times
- rlkeeney
Cool. Then the designer had it right. The only ones I've seen were at car shows and hot rod magazines. They had modern engines in them.oldc6 wrote:The Ford v-8 would have been in that car.
I'll bet I'm not alone.
