Best use for extra shopsmith
tjp1234
Post by tjp1234 »
Hi, new to the forum and new (old) shopsmith owner.
I've been interested in shopsmith for a long time. I need the space saving features and I'm terminally fascinated by "clever" machines. Finally, picked up a used unit via classifieds to help with some home improvement tasks going on.
First problem is that a couple of bits are missing, looks like I can get those used from ebay or new directly from shopsmith.
Second problem, I ended up with 2 units. I settled on a Mark V 500 because the guy with the 510 flaked-out. But then the guy with the 510 came back with an offer I couldn't refuse. So in the span of 1 week I now have 2 shopsmiths in my garage. The table system is so mush nicer on the 510, so I'll keep that.
But what to do with the 500? Looking for advice on options.
1. Throw it out?
2. Use the 500's pivot casting on the 510 to create a double tilt system?
3. Part it out on ebay?
4. Saw down the cross tubes to make a small power station/accessory storage stand?
5. What else?
wa2crk
Re: Best use for extra shopsmith
Post by wa2crk »
#1 NO
#2 NO NO NO Won't work and could be dangerous
#3 Not a bad idea
#4 Better Idea
#5 Keep it for spare parts or refer to #4
My first choice would be a dedicated drill press(wall mount?).
A mini power station is a good choice if you need one.
The double tilt is not useful unless your motor is reversible.(besides the castings need to be altered for it to work).
algale
Post by algale »
Another vote for #4. And welcome to the funny farm.
everettdavis
Post by everettdavis »
A second machine is valuable in many ways
I can't count the Times I have used the second machine to drive the jointer or other SPT
It's a backup when one is being maintained, or service is requiring part on order.
Use it as is until you envision what you give away by shortening it. Then decide if you still want to cut
Caution: cut the same amount off way tubes as you do bench tubes which must stay longer than way tubes by same amount
Everett
The bench tubes need to be 3/4" longer than the way tubes.
garys
Post by garys »
If you have a friend interested in woodworking, give it to him. I ended up with an extra Shopsmith last year and gave it to my Son so he could enjoy the hobby too.
Deltadart
Post by Deltadart »
I had a similar situation. I completely rebuilt the 500. Had the motor rebuilt, I replaced all bearings, belts, switch, new 20'rubber cord, stripped to bare metal, then painted it emerald green. This is a fun project, now I know how to service a MkV, have a new power head should I ever need it, and a second machine which is very useful. Thought about the dedicated drill, but why give up all the other operations, even cutting the tubes to "mini" size, all I would gain is a little smaller foot print. I think you should just use it for a while and see how it goes. Can always be upgraded later.
