New Use for Conical Sanding Disk
As many of you know (if not all of you), I am preparing to move. It won't be a long move. Only about 40 miles to the other side of town. While preparing for this move, I have been stewing about how to relocate all of my saw blades. The cost to replace them would not constitute a fortune by any stretch of the imagination but I don't want to replace them at any cost.
With this in mind, I had what I now believe is going to be a good solution. Twelve pieces of card board and two conical sanding disks and two 12"x12" boxes from U-Haul make a great carrier.
New Use for Conical Sanding Disk 005.jpg (826.96 KiB) Viewed 2957 times
New Use for Conical Sanding Disk 006.jpg (745.63 KiB) Viewed 2957 times
New Use for Conical Sanding Disk 007.jpg (743.09 KiB) Viewed 2957 times
algale
Re: New Use for Conical Sanding Disk
Post by algale »
Just remember to take the saw blades off before you try to use the conical disk!
Dansmith
Post by Dansmith »
When I made a long distance move years ago, I used some scrap wood to make a solid box and put a dowel in the center and placed my blades through the dowel with something in between if I didn't have a blade carton. I did a few other wooden boxes for tools so that I didn't waste the wood that I did not want to take with me. The tools were well protected, and I still have all the boxes after about 17 years. In fact some of my blades are still in the blade box.
