Magna era bandsaw fence
- easterngray
I have an Magna era bandsaw with the iron table. Though I can clamp a piece of wood on for a fence, I was wondering if there was ever a real fence for this model. Any suggestions? Thanks and best regards, Alec
I use the Miter Gauge with the Hardware Miter Gauge Extension. I use the set screw in the miter bar to lock it in place. You can adapt a 1X6 and a rounded block for resawing. To me, this make an excellant fence and jig.
easterngray wrote:I have an Magna era bandsaw with the iron table. Though I can clamp a piece of wood on for a fence, I was wondering if there was ever a real fence for this model. Any suggestions? Thanks and best regards, Alec
- easterngray
I modified a fence from my old Delta 10 Table saw. I have a big piece of white oak I needed to re-saw, and the old delta fence with modifications works great.
1955 Mark V ShopSmith greenie New to me
Magna Band saw, Magna Jointer, Magna Jigsaw (Restoration in progress) Barracuda Wood Lathe Key Chuck System, Woodmaster Multi-tool (ShopSmith Clone)
When all else fails fallow directions.
- easterngray
- Ed in Tampa
I use the method Bill Mayo described which was the recommended method SS used for many years. When I got my bandsaw it only came with a cast iron table and what Bill describes was the method SS recommended for fence. I have used mitre guage in the slot as a fence for about 25 years and it has always worked for me.
If you ever watch Dave Marks on DIY channel he has a huge band saw table built from wood and all he does is clamps a board to it when he resaws. If you ever seen any of his work you know that method works also.
I ran across thiss on ebay.
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... 0340075913
It looks like what you are talkin about. Thought I might bid on it. Any thoughts??
Mike......... Rowlett, Texas, near Dallas
86 MK V 500/520. 59 MK 5 Greenie Shorty. SS Jointer, SS Planer,
SS Bandsaw, SS Lathe duplicator, SS Belt Sander,SS Molder & Shaper,
SS Tenon master jig, SS Mortising kit, SS 2 1/4' Drum Sanders, Ringmaster, DC3300....
It is intended to be used with an aluminum table. An earlier post showed it mounted on a cast iron table. Contact that poster to determine what was done to mount it on a cast iron table. http://shopsmith.net/forums/showthread. ... band+fence See post # 7mikelst wrote:I ran across thiss on ebay.
