bandsaw guide block
jjj240
bandsaw guide block
Post by jjj240 »
I just acquired an used ss bandsaw.
Is the attached picture default steel guide block?
i've read cool block could be a potential improvement in longer blade life and less noise.
Is it worthy upgrading?
feedback on cool block vs ceramic block would be appreciated as well.
Re: bandsaw guide block
jjj240 wrote:I just acquired an used ss bandsaw.
Yes! especially for smaller saw blades. I use them always for 1/4" blades. Even when used for 1/2" blades, I close them onto the blade and let them rub for an even cut.
GoNavy
Post by GoNavy »
Absolutely cool blocks are the best upgrade and relatively cheapest upgrade you can make on a SS bandsaw. Haven't once regreted changing over mine. Also dependent on how old your SS bandsaw is, upgrading the Guide Column Bracket (page 2 item 70 on parts guide) for the rod guard (the rod that goes up/down holding the cool blocks) greatly improves the side to side slack. Old retainer lacked an adjustment for side to side tension, over time wear causes a lot of movement, the newer retainer has a nylon screw (item 65) that takes out the slack and can be adjusted as wear occurs, for $12.63 this a no brainer upgrade. Best way to check is open up your saw and look to see if the guide rod retainer has a nylon screw
http://www.shopsmith.com/ownersite/manuals/845541.pdf
masonsailor2
Post by masonsailor2 »
Agree with all comments. The cool blocks are a vast improvement.
Paul
They cost a bit more, well a lot more but I'm a fan of ceramic. I've owned a bandsaw since the early 1970's (not a shopsmith) and I've used several different guide blocks but I've been most happy with the ceramic. I also have a set of the cool blocks for very narrow blades.
If you are interested there are several modifications that can be made to make the band saw better. Here is a link to a post on that subject:
http://www.shopsmith.com/ss_forum/maint ... t8361.html
It is a rather long read but there are a number of changes noted that I have done to my shopsmith saw.
I like 'blocks' made from lignum vitae.
JPG wrote:I like 'blocks' made from lignum vitae.
Yeh, but where can one get Lignum Vitae these days. :)
rpd
Post by rpd »
On one of the forums I subscribe to, can't find it right now, some one recently posted a mallet head that they had turned from Lignum Vitae, they had reclaimed it from an old lawn bowling ball. :)
That is my point. You can't buy it new only reclaimed. I bet there is a bunch of Lignum Vitae on the USS Oklahoma at the bottom of Pearl Harbor. It was used back then for propeller shaft bearings.
dynabase
Post by dynabase »
You can get it on eBay. I got curious and looked it up. Tons of it on eBay.
Michael
