Boat Building
dafixer
Boat Building
Post by dafixer »
I've got a '05 Mark V, 520. I'm thinking of a long-term project of building a boat, roughly 22' or so, capable of handling a 70 to 100 horsepower outboard engine. I've looked at a couple of websites that offer plans and construction accessories such as hardware, fiberglassing kits, etc.
Question is, has anyone here created a boat from scratch? Do you have any pics of the process? Any guidance would be appreciated.
Thanks a lot!
algale
Re: Boat Building
Post by algale »
I pretty much covered the building of a canoe start to finish here. Search for the phrase "slow boat to nowhere." Other members have built boats bigger boats.
newportcycle
Re: Boat Building
Post by newportcycle »
There are some really good build threads here http://forum.woodenboat.com/ and here http://www.glen-l.com/phpBB2/index.php
Very friendly and knowledgeable folks on both of those forums. Good luck, will be a very challenging project.
Hobbyman2
Re: Boat Building
Post by Hobbyman2 »
Years ago I found some good info at the library . they had several books on boat building.
dafixer
Re: Boat Building
Post by dafixer »
I've looked over all the links that you all have provided and even downloaded some digital books. It looks like I should really concentrate first on the style of boat I want to build (16' to 20', motor boat for sure but, flat bottom or skiff or v-hull) and get the curves and angles right, on paper, before I start cutting wood. Also, I'm wondering if I should use planks of white cedar (I think it is also called Juniper) or thin layers of plywood that will flex and bend with the curves I select. Has anybody had any experience with Juniper?
benush26
Re: Boat Building
Post by benush26 »
Another source could be Mike Young. Though he built a sail boat rather than a motor boat, he might have some tidbits. If he is doing a demo in your area, you might stop by.
Be well,
Ben
videobear
Re: Boat Building
Post by videobear »
Marine plywood is a very friendly material, especially for novice boatbuilders. Do some research into the so-called "stitch and glue" method of building.
I have a stitch and glue kayak that's very attractive. It was built from a kit by Chesapeake Light Craft, http://clcboats.com
jbergen
Re: Boat Building
Post by jbergen »
Yes, I built a 15' sailboat with my 510, and am currently building a pair of kayaks. I have a blog with construction photos. Google "boatbuilding with a shopsmith" to find it.
-Joel
shipwright
Re: Boat Building
Post by shipwright »
I spent the best part of 35 years building boats from 19' to 60', all wood. I am available as a resource when you get going. For a beginner I would second the suggestion above to look into stitch and glue plywood construction. It is a very forgiving medium.
What ever you do, start from a good set of plans from a reputable designer.
