Pin Chuck
easterngray
Pin Chuck
Post by easterngray »
I have recently learned about pin chucks - boy they are a great,simple tool. Any ideas as to where I might get a pin chuck made for my Mark V? Thanks - Alec
a1gutterman
Post by a1gutterman »
Tim
RobertTaylor
Post by RobertTaylor »
if you are refering to a pin chuck for pen turning i made my own will get more info for you if that is the type you want. it is completely different than what tim is showing.
easterngray
Pin Chuck
Sorry for the confusion - BettyT is referencing the sort of pin chuck I mean Tim - take a look at this video of a fellow that turns duck calls - he explains the pin chuck that I am speaking about. BettyT anyhelp you can give would be appreciated! Thanks - Alec
http://youtube.com/watch?v=Odu1cT3AwUE&feature=related
RobertTaylor
at http://www.penturners.org There is a tutorial on the front page about making an O-ring pin chuck.
http://www.redriverpens.com/pdf%20files ... rt%201.pdf scroll down til you find making closed end pens.
hope this is useful, bob
gregf
Post by gregf »
Pin chucks are a new one on me too.
If you find a chuck with a 1" x 8tpi spindle, Penn State Industries makes an adapter to fit SS.
http://www.pennstateind.com/store/L5818.html
BettyT, thanks for the info, may be time to fire up the metal lathe to make one.
Richwood, OH
There is no such thing as an unsafe tool, only unsafe owners. If you make a machine idiot-proof, God will invent a better idiot.
RobertTaylor
i used a 1/4" bolt about 5" long. i cut off the head and the threads then also cut the head off a 1 1/4" finishing nail for the pin. i then carefully filed a flat on the bolt about 1/4" from one end measuring carefully with a dial caliper to keep it flat until i got the same diameter of the original bolt with the pin and bolt together (.247) if i remember. imho the whole project only took about 15 minutes though and works quite well, bob
the o-ring type appears to be more forgiving therefore quicker and easier.
greg, thanks for the tip on the penn state adapter. i do indeed use that adapter with my nova midi chuck as nova only sells a shopsmith adapter for their bigger chucks.
easterngray
That's great guys - thanks. Alec
woodburner
Post by woodburner »
Not sure which type of pin chuck you are referring to. The two I use are as follows:
There is what some call a "pin chuck" which is also known as a pin vise. You use this to hold very small drill bits for boring very small holes in wood/metal and plastic. I use this all the time in my model railroad building.
There is also a pin chuck known as a "key chuck". You use this mostly on lathes to hold small work projects. This uses a "pin" or "key" that is used in between the material and a flat on the chuck. You bore a hole in the material, slide it onto the chuck, and then wedge the "pin/key" in between the material and the chuck by giving it a twist, locking it into place. By the sound of your question, I think this is the one you are referring to.
Got anymore questions, be sure to ask.
Sawdust & Shavings,
Woodburner:o
jbooher
Post by jbooher »
Packard Woodworks has a pin chuck for $17.
http://www.packardwoodworks.com/Merchan ... gory_Code=
