SS Accessory Cart & Bench
ARCretired
Post by ARCretired »
Mostly Finished Cart
Cart Pictures 2.tiff (1.02 MiB) Viewed 12307 times
SHOPSMITH ACCESSORY CART – VERSION 2
The original accessory cart (see my earlier posting) worked very well for me, but I decided to make a second version with a couple of drawers and a bench top with a vise. Sometimes you just do things because it seems interesting, and for the fun of it. Having an extra bench surface and large vise isn’t a bad thing.
DIMENSIONS & COST – The lower cabinet is 32 ½ wide “ x 22” tall x 16 ¾ “ deep. Dimensions were driven by wanting to use a sheet of ¾” plywood efficiently and to be able to store long lathe tools in a drawer. The overall height with casters and bench top is 31 ½”. The bench top is slightly over 36” long and 18” wide. The vise opens 16” – driven by the keeping the pipe lengths completely under the top and the pipe supports about 20” apart. There is about 14” of space between the pipes, enough to clamp fairly wide boards. Total cost for the project was about $200.
VISE Two ¾ “ Irwin pipe clamps were used to make the Moxon style vise. The release mechanism is a threaded rod with two levers and bolts. Rotating one lever disconnects both reaction ends and a clip (to be installed) keeps them disconnected while adjusting the vise clamps. The clamps ($13 ea) utilize multiple steel strips and a spring on each end to grip the pipe. This also allows the screw ends of the clamps to be easily taken off and a different vise jaw installed. Separate jaws could be installed for each clamp for independent tail vises. The total cost (clamps, pipes, release mechanism) was about $50. Several holes were drilled in the top for clamping dogs. Since the vise opens to 16” only a few holes are needed for complete adjustment coverage.
BENCH TOP - The top is made from 2x 6 pine boards, ripped into 2 ¾ ” strips, then run across jointer. The center section is tied together by 6 - 3/8 “ x 10” Spax lag bolts and 8 – ¼” x 5” Spax lag bolts hold the outside blocks where the clamps are located. The top is supported by 4 – 6” x ½” full thread carriage bolts. The bolts are installed from underneath the cart top, secured by washers and nuts to the cart and washers and nuts on both sides of the bench top. The bench top with pipe clamps weighs about 35 lbs.
OTHER COMMENTS: Full extension soft close 14” bearing slides ($30 for both drawers) were used for the 15” x 30” drawers. Casters are rated at 175 lbs each and have a lock for the wheel and the carriage - About $8 each at Lowes or Home Depot. The underneath storage dimensions are nearly identical to the original cart – 12 ½ “ height. 31” width, and about 7 ¼ “ depth on each side.
algale
Re: SS Accessory Cart & Bench
Post by algale »
Not sure if others have the same issue, but I cannot see the image.
algale wrote:Not sure if others have the same issue, but I cannot see the image.
Me either.
ARCretired
thanks - forgot to upload attachment. Let me try again.
Cart Pictures 2.tiff (1.02 MiB) Viewed 12289 times
ARCretired
let me know if still not visible.
ARCretired wrote:let me know if still not visible.
It is not visible to me. I am not certain but I suspect that this forum does not handle TIFF. I just attempted to submit a TIFF file and was unable to.
Hmmm. I just looked again and I see that it has been viewed 10 times so I don't know.
algale
Post by algale »
Still a no go.
ARCretired
I uploaded file as a JPEG, perhaps the TIFF format is a problem.
ARCretired wrote:I uploaded file as a JPEG, perhaps the TIFF format is a problem.
I see them now but only as a collage. I can not view each image individually. Pretty neat work bench. You can be proud.
algale
Post by algale »
I wish I could see the photos individually/larger, but the workmanship looks excellent!
