Older Mark 7 parts diagram/manual
olafborowski
Post by olafborowski »
Hi folks, just picked up a used Mark VII (older model). Really like the machine.... Need to get some replacement parts for it and the user/maintenance manual with exploded views etc. Anyone out there that has the above manuals in PDF format? I checked on shoptsmith web site but no luck.
I am in the process of rebuilding the machine, disassembly, powder coating most parts etc. but some parts are in pretty bad shape. Is there a different name for this beast? Most of the searches just show the newer Mark VII model.
Thanks for your help,
Olaf
Shopsmith Mark VII
Shopsmith Mark VII
Re: Older Mark 7 parts diagram/manual
The 'older' version pictured is a Mark VII(ignore that 'Mark 7' tag on it).
The current model is a Mark 7.
Yes it is confusing and illogical.
Have you discovered Everett's thread?
He should appear shortly with info you need.
Hi, If you have not done it yet go to the top listing of this section for "Shopsmith Large Format Drawings, Illustrations and more" by Everett Davis. There you will find the Mark VII Manual, Parts list and all things Shopsmith. Everett did a wonderful job gathering this information and adding to it to help everyone. As far as replacement parts for the old Mark VII they can be hard to come by. The Shopsmith Mark VII was made in the 1960's and should not to be confused with new Mark 7 available today, although they provide the same functions. As JPG said ignore the Mark 7 tag under the power buttons. When looking for parts on sites like eBay go by Mark VII listings and use the pictures to compare to the part from your Mark VII that you need. The most common reported problem has been the cam used in the speed control. It is plastic and can melt. The Mark VII speed control is different than the Mark V speed control. There have been some sellers on eBay that have made 3D printed replacements of the cam to sell. There was also one who did a cast metal version of it. Most of the major components for the Mark VII are different then their Mark V counterparts. The headstock, tables, miter, tailstock and more are different. Most of the parts connected to them are not interchangeable. Some accessories are specific to the Mark VII such as its Shaper Fence. The Mark V headstock can replace the Mark VII headstock if the rack is removed from the way tubes. Doing that you will lose the reverse function but replacement parts for the Mark V headstock are available. Good luck and remember you can always come back here for additional advice.
