GREAT looking picnic table there Cowboy. Did you use cedar? Not sure if I want the plans, then I'd HAVE to two of them. BUT that would be easier to do them both at the same time.
SS 500(09/1980), DC3300, jointer, bandsaw, belt sander, Strip Sander, drum sanders,molder, dado, biscuit joiner, universal lathe tool rest, Oneway talon chuck, router bits & chucks and a De Walt 735 planer,a #5,#6, block planes. ALL in a 100 square foot shop. .
Sorry I haven’t posted this before now. It has been a busy time here with over 20 days of 90°+ days. I keep heavy refrigeration (400 ton up) running, even though I am retired.
Here are the plans I drew for the kid’s picnic table. Nothing fancy. I have changed the inside width measurement from 12” with 4” overlap on the seats, to 14” with 3” overlap on the seats. The 3 year old range of toddler do not have enough butt surface over the support if they sat on the end and the table wanted to tip. I also added a ½” x 2” brace under each seat.
I used ½” cedar pickets from Lowe’s (9 @ 89¢) and sanded with the conical disk. All joints are glued with 7/16” long ¼” dowel pins, hidden (And not shown in the plans). (I used no metal connectors.) Two adults stood on the top with another adult on each seat (600#+).
Thank You Cowboy+ for the plans. And for the tip about using cedar pickets.
A question: Is that a center brace under the table top, between the legs? What angle did you use for each end of the legs?
