Strip Sander Eccentric Part Number
wdphillips
Post by wdphillips »
I picked up a SS strip sander that did not have eccentrics on it. I grabbed a spare pair that I had and tried to use them but they are way too short to line up with the upper power coupler.
I looked at the parts list that came with the strip sander and it has a 513776 part number. When I use that number in the SS search it comes up with 5737769, but does not have a description for what the eccentric should be used on.
I checked the part list for the band saw eccentric and it shows a 5137779 and the description for use is the Band Saw, Strip S...
I assume Strip S is Strip Sander?
Can someone help me out with the right part number for the Strip Sander Eccentric part number?
I really would like to order the correct part.
Re: Strip Sander Eccentric Part Number
5137769 is the part number for the legs that fit the strip sander. They are not cheap as I managed to loose my set and had to replace them, at $18.52 each, of course they still could be hiding somewhere in the shop but that was some years back now so I have a feeling they went out in a box with trash....
wdphillips
Thanks Ed
