I bought one of these today. Ever since we bought the new house I have been attempting to develop an as built floor plan for the house. Measuring and remeasuring the spaces has not bee a successful endeavor, I hope this helps! But, if it doesn't it is still a fun tool to have in my tool box (along with my Zircon stud finder).
https://www.boschtools.com/us/en/boscht ... -177548-p/
Bosch Measuring Tool
Re: Bosch Measuring Tool
I don't recall the model one of my sons has but he used it to measure for trim in his house. I would not have guessed it would work as well as it did. I think you will like it.
We use those in the property claims business. I can't imagine going back to the old tape measure way of measuring rooms and othe stuff.
Jack
Jack
I did not expect it to be as accurate and repeatable as it is. I find it to be very useful and easily accurate to a 1/32" IF USED RIGHT. It is sensitive to light conditions and roughness (smoothness) of the surface being measured. Not good if hand held (OK for rough measurements).
I might need to buy a second one to improve my chances of finding one when needed.
- twistsol
I have a "similar" Crafstman model which has lasted a long time both is otherwise disappointing. It is accurate +- 1/2 inch and has a range of up to 32' anything over 16' though and it dispays the actual measurment - 16' so 20'4" becomes 4'4" It meets my needs for floor plan layout when remodeling and estimating but I know its limitations.
Oddly, for no apparent reason, it also has a feature tell you the temerature in the room. Apparently some product designer thought people frequently need to know room size and temperature.
Thanks much,
Chris Phelps
Cheap tools are too expensive
2x Mark 5 520 and a 10ER
Chris Phelps
