Flag Day USA
Flag Day USA
Where is your flag flying?
Mine is out, is yours?
Re: Flag Day USA
Yup!! Every day is "Flag Day" here. I am pleased to be able to report that several of my neighbors fly flags too. I only wish that a couple of them would abide by customary rules of flag etiquette. Rules like don't leave it up after dark unless lighted and don't fly it in inclement weather.
garys
Re: Flag Day USA
Post by garys »
Likewise, mine flies every day of the year unless we are having bad weather.
Re: Flag Day USA
Mine used to fly all the time but a while back the rope broke after 20+ years of use and I have to figure out how to get to the top of the 30' pole to install a new one.
Re: Flag Day USA
jsburger wrote:Mine used to fly all the time but a while back the rope broke after 20+ years of use and I have to figure out how to get to the top of the 30' pole to install a new one.
[youtube]https://www.youtube.com/watch?v=ncn4Xe6Ibis[/youtube]
:eek: :eek: :eek:
Re: Flag Day USA
:eek: :eek: :eek:
If my flag pole was that big/stout I would not mind climbing it. However, there is no way mine would support me above half way. :( :eek:
garys
Re: Flag Day USA
Post by garys »
My flag pole is only 20 feet high. It sits in a hole in the base. Two people can fairly easily lift it from the base and lay it down for repairs or maintenance. I made it that way so it is easily servicable.
Re: Flag Day USA
garys wrote:My flag pole is only 20 feet high. It sits in a hole in the base. Two people can fairly easily lift it from the base and lay it down for repairs or maintenance. I made it that way so it is easily servicable.
Mine is kind of the same way. There is a piece of 6" PVC pipe cemented into the ground. The flag pole is set in the pipe and then the pipe is filled with sand. As the pole vibrates due to the wind the sand settles. There is an escutcheon over the pipe to keep water out. So it can be removed but, I don't know how easy it will be after 20+ years. BTW, the system has worked perfectly. The pole is perfectly vertical after all those years.
Hobbyman2
Re: Flag Day USA
Post by Hobbyman2 »
Every day .
everettdavis
Re: Flag Day USA
Post by everettdavis »
See if you can retrofit your pole to one like the one in the Captain America Movie - see clip at https://www.youtube.com/watch?v=9Ag0PtH3g-s
Everett
