I have been looking for a bargain for a long time that I could salvage tubes and legs. Today I found this for $150.
I don't know what is in the boxes, but I'm pretty sure one of them has a jointer in it. Way to heavy not to be.
Found A Bargain I Think
- rlkeeney
- 20180809_115359 Shopsmith Headstock Serial Number 139814.resized.jpg (288.25 KiB) Viewed 6876 times
Re: Found A Bargain I Think
I agree. It's a real bargain.
- rlkeeney
What was in the boxes? Not what I had expected. New in the box never used. Still covered with stinky grease. I thought there would be a lot of assorted Shopsmith accessories in the boxes. I didn't open them because they were double wrapped with boxes and tied with polypropylene rope. If I had looked in the boxes, I would have left them there. Now I have yet another jointer (3 of them) and a Jigsaw I don't want. If you live near me, I will let you have them cheap.
- rlkeeney
The Jointer cleaned up nice. Only a little pitting on the end of the table where the box was badly damaged. All the parts are there except the manual. This is a newer one than the one I already have. I like the way the guard mounts much better. You just tension the spring a bit and drop it into a hes shaped hole.
Looks like a 6 inch jointer?
- rlkeeney
It is 6-inches x 36-inches.algale wrote:Looks like a 6 inch jointer?
If I remember right the shipping weight is 110lbs. I bought one from Harbor Freight before they were a chain store. They are made in Taiwan. Mine worked great for me. I can put it on the Shopsmith pretty easy but that is about as high as I want to go with it. it sits on a stand on the floor most of the time.
I have two of them now.
masonsailor2
Wow. Definitely a bargain !
Paul
Paul
That guard mount is the same as the original design(before the screwed down feather stick version).
