Help needed in the UK
Hello hoping someone can help a member in the UK.
My MK5 has stoped working and I have traced the issue to the starter relay. It’s fitted with a Zettler AZ2100-1A-110DE but I can’t seem to find one over here.
Does anyone know of an equivalent or other workable options.
Thanks.
Thanks.
Re: Help needed in the UK
Maybe confused?? The Shopsmith Mark V does not utilize a starter relay BUT the Shopsmith Crafters Station does.Bushell5 wrote:Hello hoping someone can help a member in the UK.
Thanks.
If you have the Crafters Station - the relay that mine uses is an NTE Electronics, R55-11A20-120F.
I have a spec sheet (somewhere). When (if) I can locate it, I will append it to this post.
I hope this helps.
https://www.nteinc.com/relay_web/pdf/R55.pdf
- everettdavis
Actually there are some versions of Mark V motors that use external motor start relays.
They connect the start windings then open. I think they were GE relays.
Everett
Everett
Mounted on the rear end cap of GE motors.everettdavis wrote:Actually there are some versions of Mark V motors that use external motor start relays.
Everett
I am not familiar with the 'zettler'(yet).
Have you considered disassembling it to ascertain why/if it is not functioning correctly?
The only thing I have found over here is a PC Board mount relay. Not a start relay and pc board mount does not make sense.
This is a good example where pix are a major aid in correctly identifying not only what a problem might be, but also what is it we are concerned with.
https://www.onlinecomponents.com/americ ... BC6AFAC7cs
That number brings up a single pole single throw relay 40A Mini Power 110VDC coil SPST-NO PCB/QC
this place might have one .?
Definitely a starter relay screwed to the inside of the headstock.
It’s a sealed unit with 3 lugs - live and neutral going into the motor, a black “hot’ wire going to the start switch.
Power is going to the relay but nothing out of it.
Zettler was factory fitted as original - I assume because it’s an export Mk V running on 240 volts.
Thanks but the problem with that site is that you need to order a minimum quantity of 500 units.
But that is the beast I’m looking for.
br549
Have you tried contacting American Zettler directly? Maybe they can point you to a distributor who sells just one. Or cross reference it to another model that Amazon or eBay sellers carry.
https://www.azettler.com/contact-our-global-offices/#
Any relay with those numbers will { should } work as a replacement ,mounting might need to be altered ,,,single pole single throw relay 40A Mini Power 110VDC coil SPST-NO PCB/QC . ebay has a few listed t 30 amps , https://www.ebay.com/itm/American-Zettl ... rk:21:pf:0
Amazon list https://www.amazon.com/PTRA-1A-120S-SF- ... fkmrnull_1
