Mark 7 Maintenance Instructions
Hello,
Brand new to the forum. Just purchased 2nd hand Mark 7 with no instructions or manual.
Search website and forum for Mark 7 Maintenance Instructions but all I can find are directions for the Mark V. Can anyone help with the maintenance for just the Mark 7, what do I take apart on the Power Pro head stock and where should I oil?
What do you clean and protect the tables with? Johnsons Paste Wax?
The machine is very clean and barely used, but I like to keep my gear running clean and its getting regular use now.
Thanks
Tom
Thanks
Tom
Re: Mark 7 Maintenance Instructions
There is nothing to oil in the Power Pro head stock. It is basically maintenance free. Tables and way tubes should be periodically waxed with Johnson's paste wax. Basically, other than the head stock the MK V maintenance procedures apply.
- ChrisNeilan
What John saidjsburger wrote:There is nothing to oil in the Power Pro head stock. It is basically maintenance free. Tables and way tubes should be periodically waxed with Johnson's paste wax. Basically, other than the head stock the MK V maintenance procedures apply.
Chris Neilan
Replies above pertain to a Mark 7.
Perchance did you acquire a Mark VII. Yes it is confusing since a Mark VII also has a "Mark 7" badge.
So is there a power switch near the rear, middle of the headstock or are there three pushbuttons(for/off/rev)?
Old Mark VII
New Mark 7
New Mark 7
The OP did say "Power Pro" head stock.JPG wrote:Replies above pertain to a Mark 7.
Yep! However was the OP accurate?jsburger wrote:The OP did say "Power Pro" head stock.JPG wrote:Replies above pertain to a Mark 7.
So thank you all very much! Yes OP did suggest Power Pro Mark 7. Glad to hear its maintenance free, very good news. Will wax as needed, already ordered from Amazon! Much appreciate the responses!
Shopsmith sells the Mark 7 Owner's Manual: https://www.shopsmith.com/ownersite/cat ... _MARKV.htm
And provides a 'Summary Manual' for the Mark 7 without charge: https://www.shopsmith.com/getting_start ... Manual.pdf
Shopsmith has Customer Service and an option (priced) to contact Engineering. Many or most questions can be answered by owners on this forum.
The Mark V Alignment & Maintenance manual is also available to download:
https://www.shopsmith.com/ownersite/man ... manual.pdf
