Hi all Merry Christmas.
I am in need of a square cutter for my duplicator. I see they are on back-order on line. Does anyone know if the Easy Wood Turner cutters will fit on the Shopsmith. There are plenty online and they are alot cheaper the SS. Or does anyone know of an alternative source. Thanks for your time.
JIm
lathe duplicator cutters
Re: lathe duplicator cutters
Yes the easy wood turner cutters or the Sorby carbide cutters will work. They do not have the same size screw hole but you can work around that. I took the screw and one of the cutters to a commercial fastener store and they had a small bushing that worked perfectly. The carbide cutters work great.
Paul
Paul
Try this site. They have a large variety of cutter sizes. They may have one that fits
https://www.amazon.com/stores/page/BC32 ... %20inserts
You can try here too. http://www.eddiecastelin.com/cutters_only
- kd6vpe
Thank you guys I appreciate the help. FYI I just got back from woodcraft and found some that fit just fine. Rikon 70-811 for 11.99 I need the square ones for a ring project and they were on backorder from shopsmith.
