grubscrew on nova G3 chuck
mikeb
Post by mikeb »
I just got a Nova G3 Chuck and wanted to know if the grubscrew should be used when setting it up.
Re: grubscrew on nova G3 chuck
The grubscrew is needed if you plan to reverse the chuck but then that requires a lathe that can run in reverse. If you have such a lathe then you should most definitely use it. If you don't there is no down side to using it anyway and that way it will not get lost.
To sum it up I would use it.
mikeb
Post by mikeb »
Thanks for the info.
Make sure you us the padded insert to prevent damage to the spindle(adapter) threads.
ChrisNeilan
Post by ChrisNeilan »
JPG wrote:Make sure you us the padded insert to prevent damage to the spindle(adapter) threads.
Padded insert? Must have missed that. Any pics?
Chris Neilan
Me too.
rpd
Post by rpd »
It is a thin, micarta, dot, There should have been two, (one and a spare) in the bag with the grub screw.
If you missed it don't feel bad I did too. Thought it was just waste they had throw in the shipment. Had to did all the shipping materials out of the recycle bin looking for it and sure enough it was there........ good thing it hadn't gone out yet. It was red I believe so not to hard to spot once you know what to look for.
rcplaneguy
Post by rcplaneguy »
Photos of this “padded insert”?
rcplaneguy wrote:Photos of this “padded insert”?
Sorry, no photo available here. My one and only is installed and I'm not about to pull it for a photo op. When I do stunts like that I am almost certain to drop it and loose it.
The wad is #9 on the attached link.
https://www.teknatool.com/wp-content/up ... rsible.pdf
