Pin Router Table Part Needed
I'm looking for the plexiglass front guard that goes on the stand-alone pin router table system...part number 515161. I checked with ShopSmith today and they no longer stock this part. Does anyone have this guard who would be willing to sell it? Thanks in advance.
Re: Pin Router Table Part Needed
I don't have one of these but maybe it might work:
https://www.shopsmith.com/ownersite/cat ... shield.htm
You would not use most of it, just the plastic shield bit so a lot of cost for just that. So perhaps someone here owns both and could check it out for you. Or if you have lots of extra money you could just buy one and see.
Good idea...the shield in your link looks very similar to the one I need. However, given the cost of buying a router chuck I couldn't use with that package and since the shield may not fit my pin router setup, I'll hold out hope that someone on the forum has what I'm looking for. Thanks for the suggestion.
I am not sure that shield will work. Certainly not out of the box but it may be able to be modified to work. The pictures show what the correct shield looks like.CraigM wrote:Good idea...the shield in your link looks very similar to the one I need. However, given the cost of buying a router chuck I couldn't use with that package and since the shield may not fit my pin router setup, I'll hold out hope that someone on the forum has what I'm looking for. Thanks for the suggestion.
- Shield1.jpg (92.5 KiB) Viewed 7350 times
- Shield2.jpg (56.75 KiB) Viewed 7350 times
