Cradle plans
Backatlast
- Bronze Member
Cradle plans
I’m looking for an heirloom cradle plan that was in hands on in 1985-1987. I built one of those cradlesway back then. I can’t seem to find the plan any longer. Any suggestions.
br549
Re: Cradle plans
Is this it? If resolution is too low, PM me with your email address and I can send higher resolution version.
- cradle001resized.jpg (421.41 KiB) Viewed 18772 times
- cradle002resized.jpg (1.28 MiB) Viewed 18772 times
- cradle003resized.jpg (1.1 MiB) Viewed 18772 times
- cradle004resized.jpg (420.18 KiB) Viewed 18772 times
- Ed in Tampa
Re: Cradle plans
Woodsmith did a similar plan, the only difference was the sides were rails instead of solid wood.
I built one for my first grandchild and to date it held 7 grandchildren and 4 great children.
Best thing about it was the ability to take it apart tonstore between uses.
Backatlast
- Bronze Member
Re: Cradle plans
That’s not the one. The one I built was a rocking cradle with a hood on it. Pinterest shows the cradle but it won’t link me to the plans. Thank you.
Backatlast
- Bronze Member
Re: Cradle plans
It would be in an issue a couple of years later.
Re: Cradle plans
Sounds like this one. http://www.shopsmithhandson.com/archive ... /index.htmBackatlast wrote:It would be in an issue a couple of years later.
Re: Cradle plans
link will not work for me???rpd wrote:Sounds like this one. http://www.shopsmithhandson.com/archive ... /index.htmBackatlast wrote:It would be in an issue a couple of years later.
Re: Cradle plans
Link works fine for me on a Mac using Safari.
Re: Cradle plans
Now isn't that strange, it isn't working for me any more either,JPG wrote:link will not work for me???rpd wrote:Sounds like this one. http://www.shopsmithhandson.com/archive ... /index.htmBackatlast wrote:It would be in an issue a couple of years later.
The good news is that it does work from the Way Back Machine.
https://web.archive.org/web/20160915111 ... /index.htm
Re: Cradle plans
Stranger and stranger. Today the original link is working again.JPG wrote:link will not work for me???rpd wrote:Sounds like this one. http://www.shopsmithhandson.com/archive ... /index.htmBackatlast wrote:It would be in an issue a couple of years later.
