I'm reassembling a Shopsmith I bought completely un-assembled in a box. I can't get the quill to work correctly.
Did I assemble it correctly?
First picture is of the parts opened up to show orientation.
Second picture is of the parts when everything is tightened up.
Third picture is of the spherical washer I think goes in the head unit.
Quill issues, what am I doing wrong?
- Quill 1.jpg (166.94 KiB) Viewed 11693 times
- Quill 2.jpg (154.15 KiB) Viewed 11693 times
- sphereical washer.jpg (198.45 KiB) Viewed 11693 times
- thunderbirdbat
Re: Quill issues, what am I doing wrong?
The washer is on the wrong side.
Brenda
1998 bandsaw
2016 beltsander
jointer
overarm pin router
1998 bandsaw
2016 beltsander
jointer
overarm pin router
Thanks! I'll try it tonight.
Which way does the domed side face? Does the dome side face the spring housing or the other way?
The picture(Thunderbirdbat) is correct. Dome towards sleeve, flat against headstock rib. Brenda would not mislead thee.P89DC wrote:Which way does the domed side face? Does the dome side face the spring housing or the other way?
Ok, all is well with the quill. The list of issues slowly grinds downward thanks to all the fine members here!
