Just received my new strip sander and am in the process of sharpening my things. I watched Nicks strip sanding segement and was wondering if anyone knows where to get the surface conditioning belt he was talkjng about.
By the way I am a new member new to woodworking and new to computers! Its been days just trying to figure out how to post.
You all are really helpfull in your posts, ive learned a lot just lurking in the backround
Thanks:D
strip sander
strip sander
I am here to welcome you to this band of merry woodworkers. It is always good to have a member come out from lurking. I hope you find the forum to be as helpful as I have.
This is a great bunch of people who always seem willing to help.
Once again, welcome.
I am sorry I can't be of help on your strip sander question. I do not have one yet. Be patient. Someone will answer your questions.
I also welcome you to the forum Peterc. You will find the kindest, most unselfish people on any woodworking forum here.
I hope you also purchased the sharpening attachment with your strip sander. It's everything that Nick demonstrates and indeed can put a razor sharp shaving edge on most bench and turning tools.
The belt you seek is available from many woodworking supply houses however let me recommend Lee Valley. They have a complete on line catalogue at http://www.leevalley.com. You will find many fine sharpening belts along with the leather belt and compounds. I wish Shopsmith would also supply a belt. You will probably have to remove a bit of housing material from your sander in order to keep the belt from rubbing. It will be apparent where once you mount it.
Good luck
Arno
Good luck
Arno
strip sander
I have the sharpening attachment ,just need the leather strop, thanks for the heads up on lee valley. Looks good.I was hoping to find out about the surface conditioning belt as I do have some rusted hand tools and this looks like the perfect tools to clean them.
Again thanks for the welcome and info. I know you guys are the best from previous posts I ve read.
peterc
peterc
