Mesquite band saw boxes
STB
Post by STB »
Three Mesquite band saw boxes.
196 (800x600).jpg (293.13 KiB) Viewed 43928 times
197 (800x600).jpg (220.46 KiB) Viewed 43928 times
198 (800x600).jpg (208.45 KiB) Viewed 43928 times
Glenn
WileyCoyote
Re: Mesquite band saw boxes
Post by WileyCoyote »
And I thought mesquite was only for the grill. Those are beautiful.
Dansmith
Post by Dansmith »
Those are great. What are the approximate dimensions?
Beautiful wood! I’ve never seen that type of bandsaw box, only the ones with drawers.
Do you have any in-process photos that show how it’s done? I assume that you shell them out and re-glue the bottoms, in which case there must be a seam somewhere on the sides. And maybe rabbet the lids with a router?
Gene Howe
Post by Gene Howe »
Beautiful work. You must've started with a good sized log. The grain continuity is nicely preserved. Very well done.
rjent
Post by rjent »
Beautiful! Mesquite is truly beautiful. I have some curing now. I hope mine will look as good as yours!
Dick
1965 Mark VII S/N 407684
1950 10 ER S/N ER 39671
1951 jigsaw X 2
1951 !0 ER #3 in rebuild
STB
Post by STB »
Dansmith wrote:Those are great. What are the approximate dimensions?
The dimensions are approximately 8" X 7" X 5 1/2.
The boxes were not cut to a dimension or pattern the shape and dimension were determined by the wood grain & inclusions .
Glenn
STB
Post by STB »
rjent wrote:Beautiful! Mesquite is truly beautiful. I have some curing now. I hope mine will look as good as yours!
I cured the rounds with the bark on and painted the ends with a very heavy coat of latex to prevent splitting. They were left to dry for about 3 years. One tip. I think due to the narley grain pattern the wood will move about 1/4 of an inch after being cut and in different directions. So try to glue the bottom and side cut the same day the band saw box is cut.
Glenn
STB
Post by STB »
BuckeyeDennis wrote:Beautiful wood! I’ve never seen that type of bandsaw box, only the ones with drawers.
This was posted Dec 2014 and will give you an Idea of the process. Post #18503 https://www.shopsmith.com/ss_forum/begi ... 15703.html
Glenn
Hobbyman2
Post by Hobbyman2 »
Like! and ice job on the finish !
