Stripped 3/32 Set Screw
judaspre1982
Post by judaspre1982 »
beeg
Post by beeg »
Is it the set screw threads that are stripped, or the hex hole. Hows the shape of the allen wrench?
judaspre1982
tom_k/mo
Post by tom_k/mo »
Sounds like it may be time for an Easy-Out unless you know someone with an EDM...
beeg
Post by beeg »
IF you could get to it, I'd almost say solder(JB-Weld) a old hex key into the socket, maybe try to stuff something like paper in the socket to take up slake?
dicksterp
Post by dicksterp »
Buy a left handed drill bit about the size if the socket in the head of the set screw. Run your drill in reverse and usually the drill will catch in the head of the screw and back it right out. You can get them from McMaster Carr.
Dick
billmayo
Post by billmayo »
I find this problem quite often. I use the #1 screw extractor from http://www.mcmaster.com/ If it is not successful, I use a 5/64" drill to drill through most of the set screw and retry the screw extractor. This has worked for me every time. You do not want to pry on the Speed Control Handle as it does warp and can break around the set screw. I use an anti-seize compound only on this set screw and always use a new set screw when reinstalling the Speed Control Handle. I sent all of my Speed Control Handles to GRANY555 (Ebay Item number: 220282450124 ) for installing the steel gear. I have no problems with the set screw when using these Speed Control Handles.
Extractor For Stud, For Use Trade Bolt, and Pipe Drill O'all
No. Screw Dia. Size Size Lg. Part # Each
1 #8- 1/4" (4-6 mm) ___ 5/64" 2" 2563A11 $2.01
judaspre1982 wrote:Bob, it is the hex socket of the screw. I have a brand new set of Klein t-handle hex keys. Once I established the screw had a stripped hex socket I stopped using my good set and tried using an old 3/32 hex key. I even ground the old key down to get a good even end on it. No luck.----Dave
regnar
Post by regnar »
Depending on how far gone the set screw is you can use a powder graphite that is usually available at HD and Lowes. It has worked for me on all types of screws. You need a little resistance for this to work. If you are able to free spin then it wont work and to go with Bills Method
Here is what I usually use http://www.ezgrip.net/
judaspre1982
cincinnati
Post by cincinnati »
judaspre1982 wrote:Thanks to all who have responded. I now have a small arsenal with which to attack the problem. I will post tomorrow with my results. --------Dave
Dave,
I bet Nostradamus could predict if it will work before you try. LOL!!!!
Let's see if anyone gets the inside joke. Hint.... My aviator and his user name.
