Idler shaft sleave
Samson26
Idler shaft sleave
Post by Samson26 »
without the motor shaft spring mounted, how easily should the ider sleave
move along the the motor shaft?
Re: Idler shaft sleave
The Floating Sheave on the motor shaft should move freely. If it does not and you have the spring off remove the Floating Sheave and clean the parts than lubricate.
More help can be found on this thread
https://www.shopsmith.com/ss_forum/main ... 21879.html
