Greetings from San Antonio
I now have a 1990 Mark V in my garage. It only has the headstock, jointer and speed reducer. I do not need the other attachments so I'm happy with it. I am working more and more with metal and I plan to modify the shopsmith for that purpose. I want to be able to grind and buff metal. Essentially, I want to make the shopsmith a glorified bench grinder. I will use the lathe to turn some handles for my files and such. I will research this forum to see if someone has already done this but if you have any ideas or tips, please chime in.
I should mention that this unit sat in a climate controlled storage facility for 10 years. I am first going to replace the belt and give it a proper lube job before using it.
Thanks in advance for any help!
Grinding / Buffing Wheel Question
Re: Grinding / Buffing Wheel Question
Keep the debris off the way tubes.
Something along these lines.
Belt grinder.
https://www.shopsmith.com/ss_forum/view ... hp?t=10157
https://www.shopsmith.com/ss_forum/view ... er#p152080
https://www.shopsmith.com/ss_forum/wood ... 16321.html
https://www.shopsmith.com/ss_forum/view ... 52#p249452
and a three wheel buffing system.
https://www.shopsmith.com/ss_forum/begi ... 12519.html
Belt grinder.
