DC3300 with Rigid Jointer
putttn
Post by putttn »
I would like to use the DC3300 with a Rigid planer that has a 4" chute. Went to my local Woodcraft and got what I thought would work, a 4" to 2 1/2 reducer. Only problem is it is the same size of the Rigid chute... 4". Anyone know if there's a larger reducer to fit a 4" chute down to 2 1/2 for the DC3300? Or smaller that would fit inside the 4" chute on the Rigid?
a1gutterman
Post by a1gutterman »
putttn wrote:I would like to use the DC3300 with a Rigid planer that has a 4" chute. Went to my local Woodcraft and got what I thought would work, a 4" to 2 1/2 reducer. Only problem is it is the same size of the Rigid chute... 4". Anyone know if there's a larger reducer to fit a 4" chute down to 2 1/2 for the DC3300? Or smaller that would fit inside the 4" chute on the Rigid?
Pictures please!!!Image
Without seeing Pictures, can you buy a PVC or ABS 4" coupler to fit between the Rigid planer chute and the reducer that you bought at Woodcraft? If knot, can you buy a 4" rubber coupler (with band clamps) to fit in the same space?
Tim
lv2wdwrk
Post by lv2wdwrk »
A short piece of 4" hose will fit over the adapter and the jointer. Then your hose from the DC3300 should work.
judaspre1982
Post by judaspre1982 »
lv2wdwrk
Post by lv2wdwrk »
putttn, did you get your Rigid planer attached to the DC3300?
putttn
Post by putttn »
No, I'm still wondering how I'm going to go about fitting a 4" hose over a 4" outlet chute? I may wander up to the local hardware store and look at some rubber fittings that can be held with a clamp. I understand that the plumbing dept has the reducers and will see if they will work.
judaspre1982
lv2wdwrk
Post by lv2wdwrk »
Like I said in a previous post, if you take a short piece of 4" dust collector hose and attach it to the planer then attach the adapter to the hose, you should be able to attach the DC3300 to the adapter. I have done this in reverse with a dust collector that has a 4" intake. I used a piece about 2' long, attached an adapter then connected my 520 to the adapter. Good luck.
james.miller
Post by james.miller »
See if they sell a 2&1/2" hose to 4" OD Quick Disconnect fitting http://www.woodcraft.com/family.aspx?FamilyID=3947
Try it in the store on a machine with a 4" dust chute.
Jim in Tucson
