Peachtree is now offering SS zero clearance inserts
Ed in Tampa
Post by Ed in Tampa »
Check out the ad near the bottom phenolic ZCI for Shopsmith
https://www.ptreeusa.com/edirect_102519_alignit.htm
Re: Peachtree is now offering SS zero clearance inserts
Ed in Tampa wrote:Check out the ad near the bottom phenolic ZCI for Shopsmith
No thanks! For that kind of money i will make my own.
RFGuy
Post by RFGuy »
I tried these out several months ago and they did NOT fit my 510 (converted to 520) table. I don't recommend these unfortunately. The problem was with the front hole location. It is drilled too close to the front edge. When you insert the countersunk flathead screw it just doesn't fit or align with the Shopsmith table hole location. I had to send these back to Peachtree for a refund. I can't say if I got a bad batch for this, or if all of them are this way. I ordered two of them and both were exactly the same and did not fit. Caveat emptor
📶RF Guy
claimdude
Post by claimdude »
I got a couple of those from Peachtree several years back and they fit my 510 to 520 converted table fine.
Jack
mmcdonough
Post by mmcdonough »
There is a guy on eBay who makes ZCI's here is a link https://www.ebay.com/sch/i.html?_from=R ... =shopsmith
RFGuy
Post by RFGuy »
mmcdonough wrote:There is a guy on eBay who makes ZCI's here is a link https://www.ebay.com/sch/i.html?_from=R ... =shopsmith
Yeah, I have purchased this eBay one you show. Functionally these work great, especially since the holes line up perfectly with where they are supposed to be on the table (unlike the Peachtree one). Only complaint that I have about these is the fit. Looks like they are free hand sawn instead of a template being used. As you can see in the pic below, this ZCI doesn't track the curves and sides of the table all that well, i.e. should be a more uniform gap. Doesn't really matter though since it doesn't affect its function...just surprised that it was cut freehand instead of using a template.
📶RF Guy
I make my own and I get the same results. I cut mine with a router using a pattern that I worked hard to make "perfect". Strict examination of my table cutouts reveal that the cutouts on my four tables are not the same. Thus, my hard work yielded nothing. I did finally get the drilling template redone so that the holes do line up with the table holes.
