Menard
Menard
Has anyone ever heard of a Menard? There is one for sale on local craigslist. Seller says "This is just like like a ShopSmith and was made by ShopSmith in the 80"s for Menard and Harbor Freight." I have never heard anything about it. Any information appreciated.
Menard
I have not heard of Shopsmith making any items for Menard or Harbor Freight. I would believe they are knock-offs from overseas. Therefore, I would take a calpier/ruler with you if interested. First, measure the way & bench tubes size and distance apart, maintable leg size and distance apart, tailstock tube size and distance apart and the arbor and quill housing sizes on a Shopsmith. Then the same measurements on the Menard, So far, I find very little from a Total Shop (overseas knock-off) will fit the Shopsmith or vise versa.
lv2wdwrk wrote:Has anyone ever heard of a Menard? There is one for sale on local craigslist. Seller says "This is just like like a ShopSmith and was made by ShopSmith in the 80"s for Menard and Harbor Freight." I have never heard anything about it. Any information appreciated.
I would think that if you need any part. Your OUT of LUCK.
There is a thread here on the forum where Shopsmith lookalikes (whatabees) were discussed. One of those mentioned was a Menard.
I'll attempt to locate it and will re-post if I find it. There were photos attached and it did resemble a Mark V.
- cincinnati
Another Menards?
Saw this on Craigslist in Springfield MO. Looks like a Shopsmith, but the handles are black.
- Menards.jpg (26.34 KiB) Viewed 4769 times
Life's tough, but it's tougher when you're stupid -
This looks like a clone made by the same company (overseas) that made the Total Shop. There was a few different brands/makes made by this company before they went out of business. A quick check is to measure the way tubes. The clones had a 1.675" OD comparied to 1.75" for the Shopsmith. No clone internal headstock parts are interchangeable with any Shopsmith parts. Most of these clones had steel tables, double bearing quills, higher 1.5 HP motors that could operate on 110 VAC or 220 VAC. Some motors were reversible. I found all the clone SPTs will operate on the Shopsmith. The miter gauge slot width was what other table saws companies used, not the Shopsmith width. I still have a few of the steel tables, trunnion legs fit in the Shopsmith carriage, available with front table miter extension. I had one table miter gauge slots machined for the Shopsmith miter gauge that I sold. I believe I could have these steel main tables machined for the 510/520 miter bar with washer but noone has asked for this change. The 500 fence works on these steel main tables which are the same size as the Shopsmith table.wvthomas wrote:Saw this on Craigslist in Springfield MO. Looks like a Shopsmith, but the handles are black.
If someone wants to talk the guy down to $100 I'll go get it tonight and we can talk specifics.billmayo wrote:This looks like a clone made by the same company (overseas) that made the Total Shop. There was a few different brands/makes made by this company before they went out of business. A quick check is to measure the way tubes. The clones had a 1.675" OD comparied to 1.75" for the Shopsmith. No clone internal headstock parts are interchangeable with any Shopsmith parts. Most of these clones had steel tables, double bearing quills, higher 1.5 HP motors that could operate on 110 VAC or 220 VAC. Some motors were reversible. I found all the clone SPTs will operate on the Shopsmith. The miter gauge slot width was what other table saws companies used, not the Shopsmith width. I still have a few of the steel tables, trunnion legs fit in the Shopsmith carriage, available with front table miter extension. I had one table miter gauge slots machined for the Shopsmith miter gauge that I sold. I believe I could have these steel main tables machined for the 510/520 miter bar with washer but noone has asked for this change. The 500 fence works on these steel main tables which are the same size as the Shopsmith table.
http://springfield.craigslist.org/tls/3974517948.html
