Newbie here... been reading through posts looking for info on Lubing a 10ER.. Just got it. went the the info that came with it, read through posts here on the forum.. about using wax , and light oil or turbin oil.... but need to figure out where all these lubrication points are in the head portion of the unit.
Its a nice machine in very nice shape. the PO was a machinist, and had made table Modifications that are nice (increased the table size) .
Help with identifying locations or where to look for the info for oiling and waxing will be greatly appreaciated.
Newbie - questions
Re: Newbie - questions
Gorgeous custom table extension!
thanks, not sure its neccessary but we'll see....still have 3 boxes of parts to go through.
Ill post some pictiures if theres anything special worth mentioning.
Welcome aboard,
And congratulations, you got a beauty.
On the 10ER's there really aren't any places to oil, unless you have a speed changer, or a jigsaw.. Use a good paste wax (Johnsons original, Trewax, Briwax, etc} on the way tubes and table tubes, and quill. I usually apply it with a bit of Scotch Brite (mildly abrasive) which gets any lumps or the start of rust, and then buff it off with a clean cloth. You can also put a bit of grease on the spline end of the spindle, where it goes in the drive sleeve.
went through boxes ..LOL
and some documentation to help figure out whats what ...
Nice selection of goodies in the box.
An a real treasure, you got a Speed Changer
They really expand the speed range from the stock three speeds.
http://vintagemachinery.org/pubs/detail.aspx?id=2714
