Need some advise please
Gene Howe
Post by Gene Howe »
Bought spiral feather board that came with a standard sized aluminium miter slot insert. It has a counersunk screw with wings on the shaft that fit in slots in the insert. That screw protrudes through the feather board for a knob to loosen or tighten the board in position. So... I need to maintain that set up for it to work. All this is to say that I can't use another insert.
Now, my question is how would you set up the disc or belt sander to bring the 4 5/8" long insert down to the size needed to fit my SS table miter slot? I don't have ready access to a machine shop.
Thanks in advance for your help.
nuhobby
Re: Need some advise please
Post by nuhobby »
I am reminded that not long ago on youtube I saw Terry Gordon (of HNT Gordon planes & vises) actually chamfering an aluminum vise component with a rugged little Lie Nielsen block plane. Who knows, maybe a cutting action rather than abrasion could work?
Otherwise, it would see possible to use the disc-sander with either a very good holding jig, or by repetitive sandings down to a very well-scribed reference line. Aluminum tends to get gummy in certain abrasives, so that is something to watch for.
Good luck!
stew
Post by stew »
How about the conical sander? That may be a good option
Hobbyman2
Post by Hobbyman2 »
Any chance you could fabricate one from a piece of wood?
Gene Howe
Post by Gene Howe »
Hobbyman2 wrote:Any chance you could fabricate one from a piece of wood?
Probably could. I think trimming/sanding the sides would be faster and easier. I'll put my vast and extensive engineering skills :rolleyes: to work and devise a holder to sand it to scribed lines.
rpd
Post by rpd »
Could you post a picture of the part to help us visualize it better. :)
Off hand, I suspect that there isn't a lot of material that needs removing. The safest way is probably to hold it in a vise and file it to size. ;)
thunderbirdbat
Post by thunderbirdbat »
rpd wrote:Could you post a picture of the part to help us visualize it better. :)
I have done this with a small steel miter bar. It only took about 5 minutes of filing to fit the SS miter slot. I would also recommend getting a file for aluminum if you go this route. A regular steel file will fill with the aluminum shavings and a file card will take a long time to clear the file cutting surface for use afterwards.
Brenda
1998 bandsaw
2016 beltsander
jointer
overarm pin router
rpd
Post by rpd »
Just wondering if you could sub Shopsmith Sliding T-Nuts for that part, and keep the original in case you ever want to use it on a standard saw. ;)
https://www.shopsmith.com/ownersite/cat ... ngnuts.htm
Mike907
Post by Mike907 »
This solution posted in another thread:https://www.shopsmith.com/ss_forum/view ... 51#p265351
tucsonguy
Post by tucsonguy »
I used the conical disk with fence, in multiple passes to grind down an aluminum bar to fit in the miter slot. Did a perfect job. Just lowered the table very slightly each pass to increase the grind until it fit perfectly.
Geoff Baker
1951 10ER w variable speed electronic motor with reverse
1999 520 w PowerPro
Belt sander - strip sander - bandsaw - scrollsaw - jointer - overarm router - undertable router mounted on main SS saw table - speed increaser - speed reducer - forced air HEPA filter for headstock - 19" SS powered aluminum drum sander - index wheel system - lathe table crossslide vise system
