I recently acquired the above mentioned chuck. Unfortunately the spindle is only about 1/2". Does anyone have any suggestions on how to modify it to be used on a Shopsmith?
Thanks in advance for any suggestions.
Wood River 1 3/8" Expanding Collet Chuck MT1
Re: Wood River 1 3/8" Expanding Collet Chuck MT1
Do you have a link to the product?
It looks like WoodRiver has discontinued that model.. I found this through Google, but it is showing it with a 3/4-16 internal thread for mountingLodgepole wrote:I recently acquired the above mentioned chuck. Unfortunately the spindle is only about 1/2". Does anyone have any suggestions on how to modify it to be used on a Shopsmith?
https://www.woodcraft.com/products/expa ... 4-x-16-tpi
And this one on PSI with 1-8 female thread. https://www.pennstateind.com/store/CXC4.html
Is it possible that the #1MT shaft threads into the chuck body and is removable? If so, what is the size/TPI, there may be an adapter available to mount on the SS 5/8 spindle.
Thanks for the suggestion. Tomorrow, if it stops snowing, I'll try to take it apart. Again, thanks for both of your quick responses.
I found a "Lathe Spindle Adapter Fits Shopsmith Mark V 5/8" Spindle to 3/4" x 16 TPI Thread Chuck" for $42.50.
With the Shopsmith 1/2" router chuck, you could use the Beall expanding collets, unfortunately, they skip the 1 3/8" size.
http://www.bealltool.com/products/turni ... ollets.php
Thanks for the additional ideas!
