60's vintage Mark VII
AZWoodMachinest
Post by AZWoodMachinest »
motor will not start now. just hums when power it switched on. speed was turned down prior to shutting off. I am not sure if the problem is the capacitor or the relay. I can look up the test for the capacitor, but I do not know how to test the relay other than replacement(expensive). the relay was replaced once a couple of years ago.
any thoughts?
thunderbirdbat
Re: 60's vintage Mark VII
Post by thunderbirdbat »
Try cleaning or blowing the saw dust out of the motor. There may be saw dust in the way of the centrifugal switch.
Brenda
1998 bandsaw
2016 beltsander
jointer
overarm pin router
A likely suspect is the power switch which controls direction by switching the start circuit.
rjent
Post by rjent »
Does it hum in both rotational directions?
Dick
1965 Mark VII S/N 407684
1950 10 ER S/N ER 39671
1951 jigsaw X 2
1951 !0 ER #3 in rebuild
AZWoodMachinest
rjent wrote:Does it hum in both rotational directions?
hums in both FWD and REV
Which indicates the start circuit itself(or power switch) is not functioning correctly.
Time for some continuity checks.
