Need a measurement please...
robhix
Post by robhix »
Hey all,
I am building an updated LONG tool rest for my shopsmith lathe. I need to know the distance between centers of the upper tubes and the lower tubes. Anyone able to help out here?
Thanks in advance,
Rob Hix
nuhobby
Post by nuhobby »
Hi,
I'm away from the shop and I can't guarantee accuracy. But I had sketched one time 8-3/8" across the bench tubes (center to center) and 6-7/8" across the way tubes (center to center). I'm curious so I look forward to hearing more about it....
Chris
robhix wrote:Hey all,
Thanks in advance,
Rob Hix
These are eye ball measurements since I do not have the type of caliper to give you a real precise measurement.
The center to center separation of the upper tubes (way tubes) is 7 1/2" and the bench tubes are separated by 8 9/16".
All four tubes are 1.485" ID and 1.78" OD. Hope this helps.
I can't help but ask, if you are working on a Shopsmith, why could you not take these measurements from your own machine?
pascalore
Center to Center Dimensions
Post by pascalore »
Hey Rob,
The Way Tubes, that the motor slides on, is 7" on center.
The Bench Tubes, lower tubes holding the legs together, is 8 1/2" on center.
Center to center between a Way Tube and a Bench Tube is 7 5/8" but is on an angle since the lower tubes are farther apart than the upper tubes.
Hope this helps.
P.
Serial #12-21-93 - 510 with Bandsaw and 4" Jointer:)
Greenie with Jointer and Jigsaw:D
