The design was something I came up with, but I got some inspiration by looking at what other people have done. Overall dimensions are 43" x 26" x 1.5".
Top wood is a better quality plywood, maple top finished in light honey oak polyurethane. I used solid pine for the supports underneath, I needed solid wood as it is better for putting the inserts in than plywood or MDF. Rousseau fence and plate insert I got a great deal on, still in the box, on fleabay. Of course, that is a genuine SS leg set that I used to attach it to the SS, using brass threaded inserts and stainless bolt and washer. The carriage bolt inserts I got from Jordan Bolts out of Texas. The legs on the outer edge are the stock SS 520 legs, fitted to CI floor flange and a 3/4" pipe nipple cut in half. The post in the middle is a support for a boat cover, telescopes to fit and pretty solid, available on fleabay or Amazon. All the rest of the T-Track and accessories came from Rockler. Oh, and all the things I messed up I used JB-Weld to fill in and fix, I really like the JB-Weld Wood!
Overall, pretty happy with the end result, I certainly learned a lot doing this project. Now, I just need to pick a project to try it out on.
Regards,
WoodFrog
