When is a square - not a square?
8iowa
Post by 8iowa »
The answer; altogether too often. This year I "bit the bullet" and upgraded my precision measuring tools - not that my old ones were that precision anyway. First, I purchased a set of engineer's squares and was quickly able to determine that none of my old squares were really "square". I had several carpenter's framing squares, one of which I had used to align my crosscut sled. It was really out of square.
After seeing the Wixey digital angle gauge on one of Nick's sawdust sessions, that was my next purchase, closely followed by Shopsmith's dial indicator gauge. Wow! what a difference these tools make. After re-aligning my Shopsmith, bandsaw, and joiner my woodworking results have improved greatly. It is so much easier to join and glue truly square boards.
I've never put much money into my combination squares in the past so I treated myself to a Starrett. I have since found another quality combination square, made in Milwaukee USA, by Empire Tool ([url]http://www.empirelevel.com)[/url]. Especially useful has been their 6" pocket combination square #e255. It only cost $7.78 and is very accurate, and handy as all heck to have in my apron pocket, although I don't use it for machine set-up..
Lastly, I bought a Vertias 50" aluminum straight edge that is accurate to .003 inches over it's entire length. Once you have your table precisely at 90 degrees and parallel to the blade, this straight edge will assist you in getting the table extension level with the table. It is also useful in aligning a roller stand with the joiner's outfeed table as a support for joining long boards. Not only is this straight edge more accurate than the common aluminum "yardstick" but it will stand upright on it's own base, eliminating the need for a "third hand".
timster68
Post by timster68 »
8iowa wrote:The answer]www.empirelevel.com)[/url]. Especially useful has been their 6" pocket combination square #e255. It only cost $7.78 and is very accurate, and handy as all heck to have in my apron pocket, although I don't use it for machine set-up..
Where did you get the combination squares and the straight edge? I've been looking for stuff like this. Thanks.
beeg
Post by beeg »
Tim, here's the site.
8iowa wrote:I have since found another quality combination square, made in Milwaukee USA, by Empire Tool ([url]http://www.empirelevel.com)[/url]. Especially useful has been their 6" pocket combination square #e255. It only cost $7.78 and is very accurate, and handy as all heck to have in my apron pocket, although I don't use it for machine set-up.
8iowa
Post by 8iowa »
Tim:
The Starret Combination square came from Woodcraft, but it is available from several different sources. In addition to the 6" combination square, Empire also has a combination square with a 16" blade. I was impressed with how well it "stacked up" against the 12" Starret.
The 50 inch Veritas straight edge (# 177036) came from Highland Woodworking, http://www.highlandwoodworking.com
a1gutterman
Post by a1gutterman »
8iowa wrote:Tim:
The 50 inch Veritas straight edge (# 177036) came from Highland Woodworking, www.highlandwoodworking.com
Thanks for the sources, eight.:)
Tim
