Speed Control Modification
DLB
Post by DLB »
I'm reworking a speed control on a '91 MV. The pork chop fits pretty loosely in the brackets due to somewhat splayed brackets combined with enlarged holes in the brackets. I was implementing the Bill Mayo fix, which took care of the splaying, but found that the #10 bolt was fairly loose in the bracket holes which still allowed more 'pork chop wobble' than I was happy with. Has anyone implemented or attempted this fix with a larger diameter bolt?
Re: Speed Control Modification
Are you using a full size shanked bolt, or one of those smaller shank bolts with 'rolled' threads.
DLB
Post by DLB »
Great point! This one measures .182". Full disclosure - I'm using parts from my spare parts drawer to see if the mod will save this one, not the actual parts recommended. It turns out I don't have anything that is both long enough and close to nominal diameter. I'll have to look for a low quantity source for these parts.
The bracket holes are pretty worn though. With a small C-Clamp in place to take the splay out while the roll pin was still in I'd estimate it was still 3X worse than another used controller I had removed when I did the PP upgrade. So I'm still thinking oversize bolt.
If you do ream the holes, you will have to do the same for the quadrant or install bushings(?).
DLB
Post by DLB »
I went with 1/4" bolt so that I could thread the upper bracket hole and use a jam nut. Drilled the lower hole and quadrant to 1/4", upper hole was slightly oversize for drilling for threads. This works fine, and it saves the bracket which I normally would have tossed for excessive wear. Time will tell if it is a good fix.
