Repair Fail & Lost Wife Points
STB
Post by STB »
The conversation started something like this:
This is my favorite hair brush with all of your expensive fancy tools (Shopsmith) can you fix this? Taking a look at the broken handle it looked to be an easy an fix. A brush sleeve over a tenon. I said "yes I can fix that" and immediately started thinking about my new wife points. In these days of self isolation and 7 x 24 togetherness I need all the wife points I can get.
I found what I think is a piece of Myrtle wood https://en.wikipedia.org/wiki/Umbellularia and proceeded to turn a handle with a tenon for the brush sleeve. Using a caliper I turned the tenon as close to the original diameter as possible. I wanted a good friction fit. Inserting the brush sleeve it stuck about 2/3 of the way on, no problem I used the SS Quill as an arbor press to finish the job. In my mind all was good and I started to daydream about what I could do with my new wife points.
The first thing out of my wife's mouth was "the colors don't match" The next thing was to soak the brush in bleach water. After all it was in my nasty unclean shop. That was when things started to go wrong. The wood swelled and split the brush sleeve. And all my daydreams vanished with the loss of my wife points.
20200722_101154 (600x800).jpg (289.17 KiB) Viewed 3610 times
20200722_102810 (600x800).jpg (280.4 KiB) Viewed 3610 times
Glenn
nuhobby
Re: Repair Fail & Lost Wife Points
Post by nuhobby »
LOL!
I've had my Shopsmith since 2007. It has only been in the last 5 years that my wife "respects" what I turn out of the shop...
Chris
algale
Post by algale »
Enjoy the witness protection program -- it is your only option at this point.
ryanbp01
Post by ryanbp01 »
Would rubbing alcohol have worked?
BPR
